Buzzing through Microphone
22 minutes ago, Bayfish said:I use Discord, but I'm testing it also on OBS and Audacity of which the issue still occurs. I also just tried it on my brothers PC and the issue still appears there too.. so it looks like it could be an audio cable problem?
Either just needs to be properly leveled for speaking, or its a problem inside the headset or just a poor quality microphone. The reviews I've seen say that its a good microphone, but I wouldnt really put my weight behind a 65$ headset/mic combo and expect the moon.
56 minutes ago, Bayfish said:EDIT: The buzzing seems to stop when I touch my computer case with my hand, if this is any help.
wait
Grounding yourself makes it stop. So its just a grounding issue lol... USB audio interface will probably fix the issue.
I personally use a sound blaster xg1 for my sennheisers (as much as that will make audiophiles cringe) but it works well enough and drove my Hyperx cloud IIs for like two years and my sennheisers perfectly for another two years ontop of that, so at least for me it works quite well. It also supports that single 4-pole 3.5mm that your headset uses.
amazon link to what I personally use, and would vouch for at a relatively low price. https://www.amazon.com/Creative-BlasterX-Portable-Gaming-70SB171000000/dp/B01DLY3IW8/ref=sr_1_6?keywords=sound+blasterx&qid=1558956080&s=gateway&sr=8-6-spell
