Veriton s680g F_PANEL Connectors
WillLTT
Go to solution Solved by jake765111,
2 minutes ago, jake765111 said:
Here you go. Found this in one of your pics! Right under the Pb symbol. You can use those for connections to use.
my veriton s680g just got a new case and psu, i cant find any manual that provides info about where yo put F PANEL connectors on motherboard?
HELP :O?
HELP :O?
It normally is listed very small on the MOBO. I would try looking closer.
Did I fix your problem? Please feel free to donate to me at <Link Removed>
Any donation is greatly appreciated! Thanks!
My pc - PCPartPicker part list
3 minutes ago, ughiwanthackintosh said:
veriton s680g
Did you pull the motherboard connectors from the existing case, before you put it in the new case?
As Jake above said, they are usually silkscrened in very small letters on the mobo itself.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
i dont have experience enought to understand these labels
HELP :O?
It would most likely look something like this. image.png.1fe0f441be9bc8b6f09f2d82a5cc11c1.png
Can you please get a less glary pic. I know it can be hard with MOBOS. Also, Please try to show more!
Edited by jake765111
Added "Also, Please try to show more!"
Do you know the exact MOBO version
Take a look at this. The may not be relevant but may be worth a try.
at what
labels
1 minute ago, ughiwanthackintosh said:
its all good we all make mistakes :)
Here you go. Found this in one of your pics! Right under the Pb symbol. You can use those for connections to use.821232151_ScreenShot2019-05-24at12_00_24PM.png.9025df4834891e8fea16e7a9b7087a50.png
14 minutes ago, jake765111 said:
THANKS SO MUCH???
Just now, ughiwanthackintosh said:
THANKS SO MUCH???
No Problem. The Motherboard makers always hides it in the dumbest spots.
You seriously were asking for donations when helping people....?  (Speaking about your signature...)
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Ya. I forgot to remove it
Dude. Not cool
Dude. Not cool
Happy?
Happy?
I guess it does not remove right away
Happy?
Isn’t necessarily about me being happy, but more so we are here to help each other on the forum. Free or charge. Otherwise LMG would of monetised it already somehow (don’t mean this negative towards LMG)
Isn’t necessarily about me being happy, but more so we are here to help each other in the forum. Free or charge. Otherwise LMG would of monetised it already somehow (don’t mean this negative towards LMG)
I know. Sorry for the sarcasm. I know  now that asking for donations is wrong
