Hi everyone,
Wanted to see if people have been having bus issues on the 2018 MBP. I work as a media manager and my whole team has issues with our 10gig to akitio thunderbolt 3 bus powered adapter. We're trying to figure out if it's the box itself or if it's the MBP bus. Our machines are completely specced out minus the SSD not being fulling maxed (because who needs a 4tb SSD for that price lol).
I'd be happy to answer any questions as well.
Cheers!
https://linustechtips.com/topic/1066400-macbook-pro-bus-issues/
1 minute ago, SupaKomputa said:
what issue?
Wow sorry, just realized I didn't clarify the issue lol. We get disconnected from our server multiple times in a row and have issues reconnecting. We know it's not the server itself since we have other machines connected in different variations without disconnection issues.
https://linustechtips.com/topic/1066400-macbook-pro-bus-issues/#findComment-12590790
Bus power maybe the issue, does the server self powered?
If yes then you should disable the bus power.
https://linustechtips.com/topic/1066400-macbook-pro-bus-issues/#findComment-12590810
So your server is relying on the bus power and you transfer with a 10g?
I assume it has it's own power adapter so a bus power is not needed.
https://linustechtips.com/topic/1066400-macbook-pro-bus-issues/#findComment-12590920
Yes, the server has its own power.
I'm not sure if we're on the same page.
This is the adaptor we're using: https://www.amazon.com/gp/product/B07GQV83Y2?pf_rd_p=019ad97c-f176-43be-96b9-991a6dc65763&pf_rd_r=505Z3VNZBBH4C2HRVB88
It is powered by bus power from the laptop, it does not have it's own dedicated power.
Our setup is as follows: Lumaforge Jellyfish server -> 10gig cat 6a line ran to desk -> cat 6a plugged into the akitio adaptor -> akition adaptor plugin into mbp via thunderbolt 3
https://linustechtips.com/topic/1066400-macbook-pro-bus-issues/#findComment-12590939
