I am planning to upgrade my PC but I am a complete beginner. I just want some advice on what to get. At the moment I am thinking of of upgrading my PSU to a EVGA 650W BQ Bronze, GPU to a GTX 1660 and installing a Crucial MX 500 SSD as a boot up drive and having a few games on it. Are these a good choice of upgrades or is there something better?
My price range is around £250 for the GPU and have no preference on AMD or NVIDIA. I want to upgrade my graphics card as I use this computer for gaming and it is just not cutting it anymore.
Current build:-
CPU: I5-4690
GPU: Gigabyte GTX 960 2gb
RAM: 2x8 GB TEAM ELITE DDR3
Motherboard: H81M-PLUS
PSU: ACE 700W BR
https://linustechtips.com/topic/1066160-pc-upgrade-help/
There are new AMD cards coming out soon, they might give Nvidia a run for their money. Worth waiting to see if the pricing swings to the consumer advantage
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1066160-pc-upgrade-help/#findComment-12588482
I'd wait for a little while. AMD will be releasing new CPUs and GPUs in the coming months, and if you could save up some extra cash in the meantime you could just build a fully new system instead of just a couple upgrades.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1066160-pc-upgrade-help/#findComment-12588555
