Will there be any problem if i get less than 240 fps on 240hz gsync monitor ?
Solved by Zando_,
Just now, sahildale said:So when i play AAA titles on ultra settings the gsync will drop the refresh rate from 240hz to match the fps i am getting
Yeah, but usually they have a range. Lowest they go is 35-40Hz, you'd have to see what the range of yours is. Though you shouldn't be dropping below 100 in most titles in the first place.
Featured Topics
.HEXY ·
Posted in Graphics Cards1 -
5
Dedayog ·
2
1
mbecker ·
Posted in Peripherals2 -
Prajnaanicca ·
5
3
3
