Building a sleeper. Need help with airflow.
in Cooling
If you are building in that case you are going to want as much negative pressure as possible. 80mm fans get loud so see if you can find one on the quieter side. You can also use your power supply as an exhaust fan to help pull air through the system. Just don't get any fanless power supplies and make sure they aren't hybrid. I think that most hybrid PSUs only kick on under a certain load and not temp.
Featured Topics
okkee ·
princhiocus ·
Posted in Troubleshooting1 -
Matthewfofficial ·
2
Ksalmon ·
Posted in Storage Devices2 -
TrollFaceTheMan ·
Posted in General Discussion12 -
c0dy_42 ·
Posted in LMG Sponsor Discussion2 -
wagonmetro ·
1
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
