Hello All,
I had just built a secondary PC using parts i had lying around for awhile for a general home use case or maybe used to take the load off when i stream. but as i come to turn it on the debug light for the cpu flashes for 1 second and the cpu fans spin during that then the pc switches itself off again. I have checked for any bent pins, all power connectors have been re-connected. and there isnt much else i can think off besides maybe a dead cpu.
Thanks to any and all who help,
Regards, Midgitwarrior
https://linustechtips.com/topic/1064604-cpu-debug-led/
well ok nevermind i will keep this post open a few days just so people can see what i did to fix this issue. because it was just a random thought i had, but if someone knows why this happens i would love to know, but i unconnected the 3 system fans i had, all molex connected fans, dont ask me ask the pre-built company when it was bought a few years ago and voila pc turns on as intended and all 3 fans turn on aswell, its a very duhhh moment for me but at least i can now add it to my knowledge of things to look for on a non working pc
https://linustechtips.com/topic/1064604-cpu-debug-led/#findComment-12574284
Probably overloading the PSU, what is it rated for?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1064604-cpu-debug-led/#findComment-12574287
