Greetings forum. Please help, I'm reaching the point that I might consider just buying a new pc at this point. So my problem is as follows. My computer freezes. Times are a bit random but it's every 30 min or so. Freezes up for a good 15 seconds where I can't do anything, the sound still works though. If I'm in a game, game and everything will freeze but I can still chat on discord. Weird I know. So this happened when I upgraded my pc. I got a new power supply (antec eag 550w gold standard), ssd (Kingston 480gb) and lastly graphics card (second hand gtx 1070 Asus dual OC). So I tried reinstalling windows, this helped but not a lot. It reduced the frequency of freezes. I then upgraded ALL, my drivers. No help. After this I tried running all the diagnostics I could. Hard drive sentinel came back with nothing. Malwarebytes, came back with nothing. Tried resetting the vbios on graphics card, again, nothing. Only thing I noticed was whenever it would freeze, the Gpu usage would drop to 0%. Now since this card was second hand and previously used for mining I thought maybe it was that and after trying to troubleshoot everything else my only thought is it has to he the gpu. So I replaced it. Bought a new xfx Rx590 fat boy. Placed it in pc, installed drivers and boom! It happened again. I don't know where to go now. What could be the problem at this point. Please help
Specs:
I7 4790
Asrock z97 anniversary
Hyperx 16gb (2x 8gb)
Kingston 480gb ssd
3tb hdd
Antec eag 550w gold psu
Xfx rx590 gpu
https://linustechtips.com/topic/1064243-computer-freezing-please-help/
Is your CPU overheating? Which CPU is it, which cooling and which motherboard?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
2 minutes ago, Derrk said:
could you list your full specs?
Updated. Sorry about that. Cpu is not overheating by the way. Surely if it was overheating it would cut out completely or performance throttle a lot before then?
It might throttle the performance gradually, but it might also cause stalls like you're experiencing, especially if the VRM-s and/or the chipset overheat too.
Does the board run the latest Bios?
does the current gpu drop to 0% when the computer freezes? how old is the psu?
I will monitor Temps and let you know. What program would be best for monitoring all Temps such as on vrms if that's possible? I did update the bios somewhat recently but I can update again. Ill do that and let you know.
Gpu does drop to 0% when it freezes. Once pc comes back to it the gpu usage climbs back up. The psu is brand new, only like 3 months old.
I usually recommend HWMonitor for temperature monitoring.
Did you clean the old drivers when installing the Radeon? If not, you might want to remove the nVidia drivers (Display Driver Uninstaller DDU comes to mind).
I did manually uninstall through control panel but wi use Uninstaller too.
Friend told me it could be my ram? Is there a way to test this just in case?
PassMark Memtest86+ is usually reliable. But it can take hours to complete a single pass, and completing a single pass isn't proof that the memory is 100% stable.
I'm not sure if this applies since you switched from nvidia to an amd gpu, but have you run DDU to remove all the old drivers? Again, i'm not sure if its applicable in this scenario, but it wouldn't hurt to try
memtest86 is a pretty good program for testing ram. However, intel isn't very picky when it comes to ram but it is possible that one of the dimms died.
theres also a good console command for testing ram, but it isn't coming to me off the top of my head
I'll try memtest86 and DDU. Thanks lads.
Ok. Let us know how it goes.
Btw I'd recommend testing each RAM module alone, 1 at a time.
I'm back! So I ran memtest with both the sticks, 4 passes. First stick, after each pass says "RAM may be vulnerable to high frequency row hammer bit flips". The second stick is busy finishing its 4th pass and only returned the same message after 1st pass. Aside to that no errors. Could that be the problem?
Update in comments above!
I would assume that this isn't the problem. Perhaps try switching the ram in different slots
