Super annoyed with lighting. Not just in my computer, but I've noticed in TVs as well. When am image is produced on screen, I can't stop seeing layers. The lights and shadows and edges of colors. It all looks layered... Not blended. A perfect example is in Elite Dangerous. When I'm looking at a star, it's bright by the star, then a layer a little less bright, then a layer a little less bright... Edges of each color layer are seen perfect. Is there a way to blend the colors better... Like in life?
https://linustechtips.com/topic/1064070-layered-light/
If you get good enough monitor, I guess. Since issue is both with pixel density and color range. More pixels + more colors means that blend from one color to another can be made smoother.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1064070-layered-light/#findComment-12571188
Pre-emptive answer.
If you're seeing color banding as in the picture I provided @RancidHeart, there's nothing you can really do about it. There's a implementation flaw, for lack of a better word, with the game's render engine.
https://linustechtips.com/topic/1064070-layered-light/#findComment-12571705
