First build help
Solved by SPARTAN VI,
It will work, but you're drastically overspending in some areas and skimping in others.
Processor: Pairing a Core i7-8700 (non-K) with a H100i and a Z390 motherboard is paying for a lot headroom, potential performance, and features that you're not utilizing.
- Option 1: Go with an i7-8700K or i7-9700K instead, or...
- Option 2: Keep the i7-8700 and drop the H100i for a nice air cooler (e.g. Hyper 212 Evo, or Noctua NH-D15 at the high-end), then drop the Z390 for a H370 (or B360) board and shift that savings toward the GPU budget (e.g. RTX 2070).
NVMe SSD: Samsung 970 EVO is a great performer particularly for professional workloads, but there are cheaper NVMe's out there that offer comparable performance with higher capacities and at a better price. If the 970 EVO is your only storage, you will drive yourself mad constantly uninstalling and reinstalling software when your space inevitably runs out.
- Corsair MP510 480GB nearly doubles your capacity for less euro than the 970 EVO. It has the well-reviewed Phison E12 controller that keeps up with the 970 EVO in all but the heaviest professional workloads.
- 1TB Intel 660p NVMe SSD is another (probably unpopular) choice for its high density but inferior performing QLC-based NAND. The 660p (and many other consumer QLC drives) combine cheap high density QLC NAND with a faster SLC cache that drastically increase performance for light workloads (such as launching a browser, a game, MS Office), but suffers in heavy professional workloads. The SLC cache also diminishes as the drive fills, so you would typically want to keep the drive below 75% full in order to utilize at least 50-100GB of that speedy SLC cache.
- Power Supply: The CXM 550 will work fine. I'm sure the usual suspects will come in here with their expertise, but if the budget allows I'd simply prefer to stick to the Tier A (Mid-range) PSU's from our tiered list.
