Will it fit?
Go to solution Solved by LukeSavenije,
Just now, Venomous468 said:
Would i be able to close the side panel?
yes
but again, it's like 5-8mm space left
Hey guys! I have a coolermaster master box lite 5 case which has very bad ventilation and i also have a hyper tx3 evo on my i7 8700. So i decided to buy a new cpu cooler and after alot of searching i found this cooler called thermaltake riing silent pro red And the height on that thing is 160 cm and iam concerned that it wouldn't fit in my case, the case has 160cm of space too so iam wondering if it would fit or i might have to leave the side panel open?
https://linustechtips.com/topic/1064035-will-it-fit/
Which is plenty. My previous case's sidepanel was 2mm off the cooler. Thats close. And cooler touching sidepanel is fine too. No harm, and with metal sidepanel, thermals could even be little better.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1064035-will-it-fit/#findComment-12569226
What are your temps? The TX3 Evo should be plenty for cooling.
https://linustechtips.com/topic/1064035-will-it-fit/#findComment-12570047
