Hi um Does someone know how to stream audio from 1 pc to another pc wireless like for an example i have a 2 pc setup and im gaming on my main pc and watching a youtube video on the other and i want to stream the audio coming from my 2nd pc to my main pc so it comes out my headphones
https://linustechtips.com/topic/1063540-audio/
So just make sure I understand....
You want stream the audio from your 2nd pc to the 1st pc so you can hear the 2nd's audio instead of the first one's?
If that is the case I personally am not aware of a way to that with and free software/hardware. There might be some paid software you can do this with but I honestly cant see any advantage to or justification of the cost tbh.
-= Moved to Audio =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1063540-audio/#findComment-12563675
3 minutes ago, Sythic said:
i want to hear both
Oh, well just the same im not aware of any, hopefully another member will have an answer for you, Ive moved this topic to the Audio sub-forum to help get better results for you.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1063540-audio/#findComment-12563693
You can do this just not wirelessly, get a 3.5mm cable and connect it to the output of one pc, then to the input of the other, on the pc that has the 3.5mm sending signal into it go into audio settings and check the option of "listen to this device" (on the line in) then boom the other pc's audio will come out of the pc.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
https://linustechtips.com/topic/1063540-audio/#findComment-12563887
