First of all sry for my englih ask in the comments if anything is unsecebele :D
Helo i am building a NAS out of G3258 cpu (intel 2c 2t 3.2Ghz) 4ram (planing on 16gb soon):
and i wuld like to know:
- will it be a big botleneck with only 4gb ram
- how shuld i arange the drives *1
- do i need SSD cash *2
- is FreeNAS good or are there any other recomendations *2
- speed asstemate (my upload is ~ 100 and download ~ 20)
- can i replace HDD's with this?
*1: i have:
2x500gb
1x 1000gb
2x 1000gb 2,5
1x 2000gb (i can get them for 20€ used from a friend)
*2: i want to usit as:
- smaller partition for school back up
- remove disc from my pc and have games i dont play on there
- muvies i can acces even when not on the same network
-same with pictures (for my famely)
i sometimes do some video editing for my friends, i play games, watch movies, and some light programing (learning)
any help will be grately appriciated
https://linustechtips.com/topic/1063223-help-with-nas/
You shouldnt run FreeNAS with 4GB ram or you will have performance issues - minimum 8GB.
As you have mixed capacity drives, maybe unRAID might be better? You will lose space with FreeNAS because of mixed drive sizes.
SSD cache is good for unRAID, and for L2ARC in FreeNAS if you have minimum ram.
40 minutes ago, Sekvanod said:
*1: i have:
2x500gb
1x 1000gb
2x 1000gb 2,5
Since you have 3 x 1000gb (1TB) drives already, maybe you want to get rid of 2 x 500gb and get 2 more 1TB and have 5 x 1TB drives with FreeNAS as a RAIDZ1 which will be 4TB (3.72TB usable) of space
You should not make different partitions generally, but make a single raid, and add a folder with different security permissions for your school backup (just you have access)
Quote
Yes, you can mount the folder as a drive letter on your PC and use it with Steam etc...it just may be slower due to load due to gigabi
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1063223-help-with-nas/#findComment-12560338
