Here the workstation build I'm planning:
Any advice on how I can squeeze any more performance out of this without substantially changing the price (+$100ish is about as far as I'm willing to go)? The monitor is part of my build (I currently only have a crappy 1080 monitor and I desperately need an upgrade, so I've got my sights set on that particular monitor). Also any advice on places where I can cut back costs without hurting performance? Also, before anyone asks, yes I do need Windows 10 Pro, I'm not saving the $20 there, and I do really want that case :)
https://linustechtips.com/topic/1062996-workstation-advice/
what software?
Desktop benching:
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558647
Waiting a few weeks for new Ryzen processors to hit the market
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558648
2 minutes ago, sKeptical said:
@Jurrunio DaVinci Resolve, various CAD, and some light gaming.
then you should wait, since the only software you mentioned by name works well with Ryzen instead of single core beasts like Intel ones.
Desktop benching:
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558707
https://www.pugetsystems.com/recommended/Recommended-Systems-for-Autodesk-AutoCAD-134/Hardware-Recommendations
My first impression was right, but CAD doesn't care about core count much at all... It's all clock speed (I do H/H work and it's the same issue)
Unless your talking about graphics editing CAD... (Ive never seen Da Vinci used)
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558708
I think the Gigabyte is a better MB, and a little less expensive. If you are not overclocking, the Mugen should be fine. I would increase your SSD to 500GB. They work better the less they are filled. There are less expensive SSD choices in 500GB if you are interested. The case is a bit expensive, but you may love that one. 550W will be plenty. Some people get a Windows key off the internet for about $20, but that is up to you.
PCPartPicker Part List
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($494.89 @ B&H)
CPU Cooler: Scythe - Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($51.89)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($169.99 @ Newegg)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  ($144.50 @ Newegg)
Storage: Western Digital - SN750 500 GB M.2-2280 Solid State Drive  ($104.99 @ Amazon)
Storage: Seagate - Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive  ($79.99 @ Adorama)
Video Card: PNY - Quadro RTX 4000 8 GB Video Card  ($884.00 @ Amazon)
Case: Thermaltake - Core X9 ATX Desktop Case  ($169.99 @ Newegg)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  (Newegg $49.99)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($139.99 @ Other World Computing)
Monitor: Dell - S2719DGF 27.0" 2560x1440 155 Hz Monitor  ($319.99 @ Amazon)
Total: $2610.21
Generated by PCPartPicker 2019-05-11 13:05 EDT-0400
You have to be signed up with Newegg emails to use the codes.
Corsair PSU promo code: EMCTAUT28
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558786
This Asus Z390 Extreme4 would be fine too. It's not quite as good as the Gigabyte, but about equal to the Asus Prime and comes with an excellent Crucial MX500 240 GB SSD:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157848&utm_medium=Email&utm_source=EXPRESS051119&cm_mmc=EMC-EXPRESS051119-_-EMC-051119-Index-_-IntelMotherboards-_-13157848-S2A2A&ignorebbr=1
This BeQuiet DRP4 is a step up from the Mugen and probably equal to the H100i PRO:
https://www.newegg.com/Product/Product.aspx?Item=9SIA68V6YA3005&utm_medium=Email&utm_source=IGNEFL051019&cm_mmc=EMC-IGNEFL051019-_-EMC-051019-Index-_-CPUFansHeatsinks-_-9SIA68V6YA3005-S1A9B&ignorebbr=1
The i9-9900K is $474 at Newegg with promo code EMCTATV53.
That's a very big case. What about a Fractal Design Define R6 USB-C with or without tempered glass? Here is the previous one without the front USB-C port:
www.youtube.com/watch?v=WWaxLG2hCgo&t=1s
https://linustechtips.com/topic/1062996-workstation-advice/#findComment-12558828
