Hi guys,
So I have a laptop with a dock and a desktop PC I want to use on my setup. I want to switch between them. I need a KVM but I’m on a budget. Do any of you have good experience with a good HDMI/USB KVM under US$50? I kind of need one of those that make the computer think a monitor is always plugged in.
ivan
https://linustechtips.com/topic/1062966-low-cost-kvm/
Get a software KVM. I use Synergy myself and it works wonderful! Only way I wouldnt recommend this is if you use a VPN on either of them to connect say into to work. Synergy 2 the new version doesnt support manual configuration so it wont be able to detect on your home network as a result. I use the original Synergy and I can just enable SSL certificate and my Public IP address to talk.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1062966-low-cost-kvm/#findComment-12558379
It has one time payment options!!! Someone should’ve told me before!!! :)
what do worries me is that I don’t keep both computers turned on, and I only have one monitor.
The MacBook requires to detect the mouse and keyboard connected (either usb or Bluetooth) for it to work while closed (I already purchased a dock for it.
I found some multi-device keyboards and mice from Logitech and dell. Maybe I should get one of those and switch the monitor manually or via DDC/CI with some software.
Any other suggestions are welcome though!
https://linustechtips.com/topic/1062966-low-cost-kvm/#findComment-12558588
