Case Fan Advice
On 5/12/2019 at 2:11 AM, WoodenMarker said:The Meshift C is excellent.
The top of the P400S isn't very restrictive for airflow. Are you using the dust filters? They should be removed if you're using the top as exhaust unless settling dust is a big issue for you. What fans are you using and what rpm are you running them at?
The standard 120mm p400s case fans are up top and yea I removed the dust filter. I have it connected to the fan controller at the max speed.
After looking into it I am heavily considering moving this build to a Meshify C and then returning the p400s. I just wish they made a Meshify C2 thats an inch taller and longer since the biggest complaint is the length for gpus and aios, but this doesn't impact me since my 2060 is a two fan card and I only use air cooling now.
Edit; Returned P400S and got meshify C dark TG
