It's time to get rid of my Thermaltake P3 because I got a cat and it's going to introduce a lot more to my radiator than I think it wants to be subjected to.
I'm trying to look for a new case, but I haven't caught up with what the market has now, but this is a list of things I probably want in it.
- Vertical GPU mounting to show off my GPU block
- Tempered glass panels (more the better)
- opt. RGB fans
- 360mm radiator support
Thanks for the help
https://linustechtips.com/topic/1062813-vertical-gpu-mount-case/
PC-O11 DYNAMIC by Lian LI is one of the most popular cases for water cooled systems.. And for a good reason.. Check my sig link to see how I set mine up..
The case doesn't come with the vertical mount but they sell it as an accessory for that case.. But any aftermarket mount like the ones cablemod and cooler master make will work just as good..
Other cases I considered for the same exact reasons you are, are the P600S and Meshify S2.. Both come with vertical mounts, but not the riser cable you need..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
