Sapphire RX 570 Backplate Removal
serjj
Planning to clean my RX 570 but have no clue on what screwdriver to use, what kind of screws are these? Are these 1.4mm?
Related image
If im right(Correct me if im wrong)that should just work with a Phillips head screwdriver
It's a lot more smaller than you think
You would need special small screwdrivers like the ones in a iFixit kit or similar
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Here is a "better" picture or just something to actually show how small it is.
What kind of screw or what kind of screwdriver do I need to remove them? Please help. I really wanna clean this card (lmao)
oh , those screws will require the very technical and illusive and rare "small phillips" lol
Any small philllips will do.
Small scredrivers exist you know.
I'll just buy a kit just for this lmao, first I'll try with a 1.4mm, anyways thanks for the help.
You don't need any special screwdrivers, just use a small Philips head. It doesn't have to match up exactly with the size.
Even if you wanted a tiny screwdriver kit, your local Walmart carries them inside a case in electronics. Just ask for a set. It's like $8.
My thoughts exactly
