Hi community!
So recently, the Ethernet on my laptop has gone down. The wifi, being Intel AC 3165, is fine. When connected to my Ethernet adapter, which is a Realtek card (Just say Family controller. No models ect.), I get a no internet connection. Apparently, my laptop is sending packets to the router, but the router is not responding to the packets.
What should I do?
I have already:
Reset network
Reinstalled drivers
messed with settings(no difference)
Thank you!
Reminder
The IIA rule applies here:
I'm mostly speaking from experience so what I say may not work
I may be a complete asshole in some threads but I swear that I won't lie
Anyways, I am always glad to help
https://linustechtips.com/topic/1062664-ethernet-not-working/
Set the DNS server manually to : 1.1.1.1 and 8.8.8.8
https://linustechtips.com/topic/1062664-ethernet-not-working/#findComment-12555349
Did you try a new Ethernet cable?
They are quite cheap
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1062664-ethernet-not-working/#findComment-12555372
Quote
The Ethernet cables works fine with other PCs.
Quote
What does this do? may I have an explanation?
Thanks to both of you :)
Reminder
https://linustechtips.com/topic/1062664-ethernet-not-working/#findComment-12555437
