Pocophone F1 How to downgrade firmware?
Solved by AlTech,
So I ended up confirming that the Firmware had been downgraded by installing a new LineageOS 16 build which required firmware 9.4.26 and it installed correctly which would not have worked on firmware 10.2.3 .
As for installing it @Arika S
I ended up downloading the firmware zip on my F1 and then rebooting into TWRP recovery (press Volume Up and Power on reboot). And then just telling TWRP to install the downloaded zip file.
So far everything works. And no data was lost.
