Wireless earbuds that don’t bleed
DotzHyper
Go to solution Solved by Firewrath9,
soundpeats wireless?
I’m looking for budget options of Bluetooth earbuds that have good lows and 3+ hours of battery life. But, more importantly I’d like them to go higher in volume before bleeding the entire instrumental to everyone in the car. Will be workout headphones mainly so a decent fit would be nice. Can’t fall out but shouldn’t be an issue. I previously owned those 20$ insanely rated ones from amazon And they were okay but I lost them, and bled quite easily.
thank you any suggestions are appreciated
true wireless would be nice as well but it isn’t the end of the world If they have a wire around my neck.
What is your budget?
nothing really set but around 50, will pay more if worth
i like these, do you know if they bleed?
For budget price around there..  Anker's soundcore line are pretty decent, however they are a bit above your 50 dollar budget. If you could shell out more money, I'd recommend getting some Jabra  65t.. I currently use these daily at work and working out. One of the best totally wireless earbuds atm. Do some google searching for some reviews. They are highly praised.
Anker:
https://www.amazon.com/dp/B07PLGZ4CR/ref=cm_sw_em_r_mt_dp_U_DW30Cb4TNQ86T
https://www.amazon.com/dp/B07MCGZK3B/ref=cm_sw_em_r_mt_dp_U_IX30Cb7J223C3
Jabra:
https://www.amazon.com/dp/B077ZGRVRX/ref=cm_sw_em_r_mt_dp_U_mZ30Cb4ZXDDHK
Anker:
Jabra:
Thank you, ill probably lose them so lets not go with the jabra, but if u have the ankors can u do a leak test? Find someone and tell me how loud u can go until they can hear the backround from about a foot away.
if not, i still appreciate ur reponse.
I don't personally own the ankers. Just hear from people I know that they like them. One of them I work with... they have the liberty air's and I never really hear any music from them.
