Hey everyone,
Been having some issues with my PC. Random blue screens. Some days nothing, other days one or two and then when I'm finally on Windows, no problems. Never crashes during gaming or cpu intensive tasks. All the hardware seems good. Nothing faulty.
I've just updated my Bios, since the previous version was from 2016. We're now on 2018. Now, it's impossible to get to windows.
Here's what I get:
Kmode exception not handled
Memory management
Critical process died
Irql not less or equal
System thread exception not handled
Registry error
Pfn list corrupt
Page fault in nonpaged area
Seems to rotate between these errors. I don't know what to do. The Bios was successfully updated, then after the reboot the Bsod's started.
Please help!
https://linustechtips.com/topic/1062182-serious-startup-issues/
Have you attempted reinstall of windows? You can install it to a secondary drive for testing purposes to see if it resolves the issue. If a fresh install is experiencing this then there may be an issue with the bios update or driver conflicts with the update.
https://linustechtips.com/topic/1062182-serious-startup-issues/#findComment-12550713
1 hour ago, Optickle said:
Not yet. A Windows reinstall would be my last resort. Probably a good idea to do so anyway.
The windows reinstall seems to have fixed it! Btw, is there a trusted all-in-one program that I can use to update all my drivers?
https://linustechtips.com/topic/1062182-serious-startup-issues/#findComment-12551114
