Hey all,
After going through a few various laptop cooling pads with sub par performance / terrible fans / terrible build quality I've been thinking about modifying a broken spare one I have laying around.I would probably just change the fans,
The cooling pads I have are all powered by a male to male USB connector and use cheap 5V fans that don't seem to get to a high RPM and barely move any air.
I was thinking of using PC fans but struggling to find any way to power them at 12V other than using something along the line of https://www.kustompcs.co.uk/components/power-supplies/dc-boards-ac-adapters/phobya-70w-external-psu-230v-to-4pin-molex/ into a fan controller and powering the fans from there.
Is that PSU overkill for six fans? could I get away with the 34w one also sold on the website?
https://linustechtips.com/topic/1062151-laptop-cooling-pad/
While a great idea its generally not worth it. Repasting the laptop is just a better option
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
https://linustechtips.com/topic/1062151-laptop-cooling-pad/#findComment-12550439
5 hours ago, SammyJones said:
The laptop is new (<2months old) so I don't want to pull it apart to repaste and invalidate the warranty!
It only really gets baking hot when playing demanding games and I just want to aid the two jet engines it has for fans :P
Most of the benefit you see in performance when using a laptop cooling pad is from the bottom of the laptop being lifted off the deck. That greatly improves airflow into the cooling fans. The fans on the cooling pad are typically underpowered and do very little other than make noise.
Side note: laptops run hot while gaming. Unless it's throttling, it's not really a problem.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1062151-laptop-cooling-pad/#findComment-12551958
