Look I have a gtx 1050 asus dual oc 2 gb gddr5 128 bits, the problem is the problem that
is found in the game of text images, the measure that I approach the lines that fit, the
video card the problem, the made of the tests with the hallmark for 20 minutes that of 1900
x 1200 with burntest and all that no problem was detected, nor artifacts as well as the pass as
 300 times the user marks, I do not see graphic error in stress programs , try another monitor
 and I continue with it, he updated the drivers and it happens again the same probe another gpu
a gtx 960 and also happens again the same, on the desktop everything looks 10 but only happens in
some games , they are not artifacts because I do not see black lines when I move a character, in
assassins I believe iv I have no problem, as in assassins creed rogue, in dead or alive 5 either,
not even in fallout 3, in skyrim is where I could appreciate the problem so with the 960 as well as
 the 1050, I do not know what the problem is as if it were a stutter of textures.
https://linustechtips.com/topic/1061977-textures-problem-in-any-videogames/
