Hi all,
I have a really weird issue with UltraVNC. I use it to connect to a 2-in-1 Lenovo and everything works fine except for one thing: I can't type dots! I mean dots like [ . ]
EVERY OTHER key works, including symbols and accents (I'm on a standard Italian layout). I'm forced to copy a dot and type it using CTRL-V ...
It's Windows 10 on both sides, I really can't figure out what's wrong.
Any thoughts on how to solve this very annoying problem?
MAIN PC: CPU: AMD Ryzen 5 2400G | Motherboard: Gigabyte GA-AB350-Gaming | RAM: 16Gb DDR4 Patriot Viper 4 3200 | GPU: XFX RX580 4Gb GTS | Case: Sharkoon S25-W | Storage: M.2 NVME Adata Gammix S10 128Gb + SATA SSD WD Blue 1Tb | ODD: LG GH24NSD1 | PSU: Seasonic Core GM-500 | Display: AOC I2490PXQU | Cooler: Wraith Stealth | Keyboard: Logitech K120 | Mouse: Logitech B100 | Sound: the usual integrated Realtek | OS: Windows 10 Pro 64bit
RETRO PC: CPU: AMD Athlon 64 2800+ | Motherboard: Gigabyte GA-K8VM800M | RAM: 2Gb DDR 800 | GPU: ATi Radeon 9600 Pro 128Mb | Case: Tacens Anima AC4500 | Storage: IDE WD Blue 80Gb + IDE DVD-RW drive + floppy drive | Sound: Terratec 128i ESS Solo-1 PCI | OS: Windows 98 SE + Windows XP SP3 + Linux Bionic Pup 32
HTPC: CPU: AMD Athlon 3000G | Motherboard: AsRock B450M-HDV R4.0 | RAM: 16Gb DDR4 G.Skill Aegis 3200 | Case: Aerocool CS-101 | Storage: SATA SSD Silicon Power A55 256Gb | ODD: LG blu-ray WH14NS40 | OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/1061548-ultravnc-and-dot-key/
