Hey
I recently started looking into overclocking and how to and I've been pretty confused and also been having some trouble
I downloaded MSI Afterburner and Heaven Benchmark 4.0, but when I run it on stock settings, it seems to run faster than when I modify any of the settings.I keep increasing the core clock by 10 or memory clock by 100, sometimes together and sometimes by itself, i just mess around with it, and still I'm getting less performance than stock settings.
I do put the power limit to 110 if you're wondering.
Any help would be appreciated, Thanks.
Specs:
MOTHERBOARD: Asus Rampage IV Extreme
CPU: Intel i7 3820 @ 3.60GHz
RAM: Cosair Vengeance
GPU: Gigabyte GTX 660 OC
https://linustechtips.com/topic/106153-gtx-660-overclocking-help/
^ what @Jogostar said. Sometimes you just lose the silicon lottery.
If you are comfortable with voiding the warranty, you could flash the BIOS and overclock without limits.
http://www.overclock.net/t/1330897/official-gtx-660-non-ti-owners-club
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
My 660 OCd very easily at the stock OC but after i flashed the BIOS i am now able to do 7008MHz on the memory clock, 1280MHZ on the GPU boost clock minumum GPU voltage of 1050v and with a maximum of 1.212v and the temperture is 74C ambient of 28C. Not saying you should do it but this is how i got mine to be what it is now.  Just take your time with it and do proper research on GPU OCing.
post-3854-0-91136900-1390529090_thumb.pn
A water-cooled mid-tier gaming PC.
It's not that it won't overclock, I slide the core clock and memory clock with MSI afterburner or one more than other and the performance goes down? I really don't know...
I followed that. I am saying that i could only OC my 660 to a certain OC before it would throttle. When i flashed the GPUs BIOS my performance increased as shown in the picture i put up. Then again it may just be your GPU's characteristics. Of the five GPU tweakers i have used, I have found that GPU tweak is the easiest to use.
