2 minutes ago, Rose16661 said:
This is my first time buidling a pc, and I was wondering if the parts I chose were okay.
https://pcpartpicker.com/list/4rFZNQ
Around 950 euros is my budget.
Thanks in advance
Pretty solid AMD build.
You might want to up to a 500GB SSD if you can.  Unless you are VERY strict with your file management, windows can fill things up pretty quick.
Is the Fatboy a good buy right now?  Vega 56 is just a bit more and a lot more powerful.  At least here in the states.
Just things to consider.
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541024
Honestly, don't know why people keep paying so much for the 970 EVO when there are same performing SATA drives for double the space.  You can even get 1TB SSD for that price!!!
Also, you really only need 256 for a boot drive really if you're just gaming.   I am only using 64GB of my C drive for Windows, Office 365, all the launchers, and a few other apps.  Game libraries are on the other SSD set.
I'd either go with a 256 SATA SSD for boot, or just buy a 1TB SSD and put it all on there and lose the HDD.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541094
Not a fan of Gigabyte. Had a motherboard of them, and it literally fell apart while building.
Similar for Samsung. I'd swap out Samsung for a regular SSD, from Kingston for example. I'd keep the HDD though, especially for larger games that can take a lot of space (e.g. BF1).
Tbh, I've never heard of SeaSonic so can't say anything about their PSU. Have you checked the wattage for your build?
Be Quiet! for example has a Power Supply calculator: https://www.bequiet.com/en/psucalculator
(not saying you have to get one of their brand, but can help to check to see if you are in the ballpark or need to go up (or down))
I like the combi of the Ryzen 7 and the GPU. You could check some YouTube videos to see how they fair (together). That can give you some idea too. I'm not familiar with the exact specs and performance, but the look decent at first glance.
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541306
Would the B450 Gaming plus make a better motherboard?
The calculator says it would require around 400 watts, but Im rather save than sorry.
Thank y'all for your input
Edit: the vega 56 is around 70/80 bucks more expensive which is a bit too much.
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541473
Maybe, it is definitely cheaper, but it only has one PCI slot for example, which could hurt expansion.
I was just looking at the ASUS Prime X370 PRO, that is around the same price range, and comes with a solid feature set:
https://www.asus.com/Motherboards/PRIME-X370-PRO/
I've only read one review of it though, which was positive.
As for MSI boards, made a quick selection of Asus and MSI motherboards on partspicker around your price range:
https://pcpartpicker.com/products/motherboard/#s=33&f=2&X=0,12535&sort=-price&m=8,27
I've had several MSI boards and love them, don't know too much about ASUS.
Things I would look for:
1. Build quality
2. Power handling, can it handle gaming
3. Fan header amount (Edit: although you can add a fan controller later if needs be for example)
4. PCI-E slots, do you want to use multiple GPU at some point, then from what I know the second PCI should at least be x8, x4 will bottleneck (but this may have changed)
5. Amount of memory, should at least be 16gb
Edit: feel free to look at other brands too, maybe other people have suggestions as well of course :)
Edited by bluesky_dolphin
typo correction
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541524
1. Build quality
Thanks bro, I'll take it all into consideration
https://linustechtips.com/topic/1061222-first-pc-build/#findComment-12541711
