Hey LTT group i am a big fan of you guys and i am wondering if you can maybe help me out today i built a new system yesterday but i cant figure out why my screen has 1 vertical line in the middel it disappears now and then but it comes back everytime its annoying
My build is
Msi x370 sli plus mobo
Amd ryzen 5 2600x
4gb ddr4 2400mhz didnt have enough money to get more
Coolermaster box 5 lite rgb
535 psu raidmax rgb aswell but not connected for rgb
And Rx580 8gb oc edition aourus
Can someone help me i tried litterly everything
I even went back to your videos for guides on how to build to see if i missed something but nothing can someone plz help
I am in South africa so i did not have alot of money and stuff is expensive as hell this side to buy the best screen or a 144hz screen i just have a normal hdmi dell monitor s22hl
https://linustechtips.com/topic/1061161-i-need-help/
1 minute ago, Jacobtechtips? said:
1. Check the video cable is seated properly
2. Try another cable
3. Check your gpu is seated properly
Thought#1: Your gpu may be faulty...looks kinda like artifacting
Though#2: Your monitor may be faulty...
Tried that already as well but will do again
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540561
Did you uninstall your GPU drivers with DDU ? If not, do so and reinstall them manually, don't rely on Windows to install your drivers.
Is the monitor operating at the right resolution and framerate?
And yes, that PSU should be giving enough power.
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540589
Yeah i did that already with ddu and installed drivers amd website not the optional one the recommended one and i think i have found the problem the gpu thermal paste was all over the green instead of on the middle piece i opended it now
How can i clean that off
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540617
Monitor is running as recommended by the box not overclocking or is super res doing it  on amd settings but its running 1920x1080
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540618
That's normal and the paste is non conductive. They usually put a buttload of it on there to make sure it's 100% covered, hence why it "spilled out" onto the green part.
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540625
Okay well lets see if it does the line cause i knkw the monitor is older then my build
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12540749
11 hours ago, Jacobtechtips? said:
Nice to know..hopefully it stays that way ?
Wellit did not started this morning and i have seen its a dead pixel need to buy a new monitor
Can anyone recommend one thats for gaming but not too expensive like for me zar format please
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12543702
i know i might be new to this group on the web side but i have been watching you a long time so may i ask for a sponsor screen since i don't know how am gonna be able to get once since i have no job  and my pc will be useless after the screen goes or anyone know how to fix dead pixels
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12543726
Well idk how to fix dead pixels but i do know a pretty good gaming monitor:
LG 24mp59ht...its 1080p, 75hz and has freesync for your gpu and i can say its pretty darn good (i own it)
https://linustechtips.com/topic/1061161-i-need-help/#findComment-12543821
