Sup people! I'm trying to build a relatively portable entry level workstation PC. Some games will be played occasionally, I mostly do video and picture stuff.
Important point:
  • Micro ATX build.
  • case needs to have one 5 1/4 inch bay. ( yes I still use CD sometimes)
  • I have two hard drive for an external raid 1 card.
TELL ME WHAT YOU THINK, I WANT YOUR FEEDBACK!!!
Case: Bitfenix prodigy M
CPU: Intel core i5 4670K
CPU cooler: corsair H75
Mobo: ASRock Z87M Extreme4
RAM: Patriot viper 3 16Gb (2 x 8Gb)
Storage: 1 x intel ssd (already have) 2 X Seagate 2TB drive in raid 1
power supply: Corsair RM650
Raid card: http://www.canadacomputers.com/product_info.php?cPath=48_19_918&item_id=037843
Video card:   EVGA GTX 760 with ACX cooler,  http://www.evga.com/Products/Product.aspx?pn=02G-P4-2763-KR
https://linustechtips.com/topic/106060-entry-level-workstation-need-advice/
For future reference, if you are asking about build planning, please post in New Builds and Planning. The build log section is designed for people that are already in the process of building their rigs.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
What kind of work is being worked on? Programs being used?
Budget?
I'm moving this thread to the New Builds and Planning section.
Build logs is for showing off the process and result of your build with pictures and stuff, not planning new systems.
