Hi, I want to build my own pc under 850 dollars but it's too difficult for me. HELP ME!! First of all, I mostly play League of legends, Pubg, and Apex legends and also I'm an architecture student so I would like to use at least 250gb SSD and 16gb RAM(2 x 8gb) for my computer. I've been planning to use AMD Ryzen 5 2600 or 2600k over Intel because as far as I know, it's better for 3D modeling, etc... And I would like to get GTX 1060 6gb or 1050ti but I have no idea what manufacturers I should choose. Furthermore, I want my PC look pretty with White LED so I am considering NZXT-H500i white Mid Tower case with Corsair white RGB RAM. I heard that the CPU needs a decent cooler. I prefer RGB liquid CPU cooler.
Briefly speaking, help me build PC(CPU, CPU cooler, Motherboard, Memory, SDD, Video Card, Case. Power supply, Hard Drive, Monitor.
*English isn't my first language, so please excuse any mistakes. :)
https://linustechtips.com/topic/1059799-first-building-suggestion/
Welcome to the LTT forums! May you please post the link to your build? Also as far as GPU brands go I recommend EVGA as they even warranty damage from overclocking, while they also have some of the best GPUs in the business. Also I recommend taking a look at the faster and possibly cheaper GTX 1660.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
9 minutes ago, Tim Ji said:
Mexico and 800 to 1000 dollars
No data on prices or parts stock from Mexico, so do double-check
But here is a rough guide anyway
No need for a cooler, the AMD stock cooler is pretty decent
Vega 56 is much better than a GTX1060 but I'm not entirely sure if Mexico has that many of it? Maybe go used?
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.39 @ OutletPC)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.88 @ OutletPC)
Memory: Team - T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($90.98 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  ($69.95 @ Adorama)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: PowerColor - Radeon RX VEGA 56 8 GB Red Dragon Video Card  ($319.99 @ Newegg)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Cooler Master - MWE Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Amazon)
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($19.88 @ OutletPC)
Total: $984.94
Generated by PCPartPicker 2019-04-30 22:55 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
Total: $984.94
In the Newegg, Ryzen 5 2600k is cheaper than 2600 due to sale. What should I get?
If the 2600X is cheaper then you can get that, though I would still recommend waiting for Ryzen 3000 series if this isn't urgent.
Since likely those sales are them getting rid of old stock in anticipation of the new Ryzen chips
Thank you for your suggestion. Any reason you recommend the right one?
Saves space and no need for SATA power cables since it connects directly to the motherboard which also leads to easier cable management. You can connect one less cable to the modular PSU
Either way M.2 or normal SATA works, just up to you depending on availability and price.
