Ryzen questions
Go to solution Solved by Fasauceome,
32 minutes ago, Drygur said:
 yes he has a GPU already and he's looking to spend $800-900
I aimed under your budget to show you a still good build for a budget minded expenditure
You definitely won't be able to take advantage of the increased speeds of an NVMe drive in a gaming focused machine, so I opted for more capacity on a standard SATA SSD instead. I lowered the ram amount as well, even 8GB is suitable these days but 16GB is a very comfortable amount to have, and retained the 3200MHz speed. Better PSU than the B3, but not really by a ton. For as much as you were spending on the EVGA B3, you can get this if you wanted something really nice:
https://pcpartpicker.com/product/zBfmP6/bitfenix-formula-gold-550w-80-gold-certified-atx-power-supply-bp-fm550ulag-7r
I was putting together a PC for my friend he doesn't have a lot of money to spend so I was trying to keep it on the cheaper end. I've only ever built intel machines but I know Ryzen was performing really well so I tried to put an AMD build together. I think I read you need high frequency ram for Ryzen but I wasn't sure if I also need a lot of available memory 32gb v 16gb. So thought I'd ask here
https://pcpartpicker.com/list/9N77V6
https://linustechtips.com/topic/1059725-ryzen-questions/
24 minutes ago, Drygur said:
That's not a great build. What is your friend's PC intended to be used for (e.g. gaming, Chrome, video editing)?
Make sure to buy 3000 or 3200 MHz RAM for Ryzen, and go with a 16GB kit since 32GB is overkill for most people.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12527838
Memory size isn't important. You're fine with 16gb if you're gaming. What matters for performance when it comes to ram is frequency and latency. You ideally want around 3000mhz at least with cl16 or lower. 3200mhz cl14 seems to be the best spot right now for Ryzen as it can't go any higher frequency anyways for the most part (You can get 3466 and maybe even 3600 on a very lucky day if you know what you're doing)
Also, change the psu. You can get so much better than that psu for the price (Changed to a far higher quality corsair rmx):
I don't know what your use case and budget is so...I'll just leave it at that and let the rest do the work.
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12527853
Better 16GB, + 1TB mx500.
But let’s await budget first :)
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12527906
Its about $150 more, but you get a GPU added which unless your friend already has one I'm not sure how they are gonna have display.....
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.49 @ SuperBiiz)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.88 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  ($69.95 @ Adorama)
Video Card: PowerColor - Radeon RX VEGA 56 8 GB Red Dragon Video Card  ($319.99 @ Newegg)
Case: Corsair - Carbide SPEC-04 (Black/Red) ATX Mid Tower Case  ($24.99 @ Newegg)
Power Supply: Cooler Master - MWE Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Amazon)
Total: $859.28
Generated by PCPartPicker 2019-04-30 20:48 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12528357
Yeah I wasn't sure if Ryzen just needed high frequency or a lot of RAM (16gb/32gb) wasn't sure if I could go down to 16gb
He wants to be able to run games and stream without lagging and he already has a GPU (GTX 970 I think) that he can always upgrade later.
On 4/30/2019 at 4:55 PM, Lurick said:
Does he have a GPU to use already?
What's the budget and use case?
Thanks, wasn't sure about the RAM which was my main concern and he is going to re use his current HDD so he just needs an SSD so I was just trying to get him a good boot drive he doesn't use much storage space. I'm really bad at choosing a good PSU option rather over shoot than under shoot
Also sorry for delayed responses
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12534023
1 minute ago, trevb0t said:
You still haven't answered what the computer is going to be used for.
Was a bit much maybe should have rehashed it somewhere mb
Gaming and Streaming
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12534051
Edited by fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1059725-ryzen-questions/#findComment-12534080
