Hey Guys,
I have a small issue here: I've got this new button, a momentary switch with a green "angel eye" led ring, which I want to use as a power button for my comp. As you can see in the rather vague and blurry pic that I enclose, it's a six pin button and I know by now that the top one is the positive pin for the led, the bottom one is the negative pin for the led, the far-left one is the control pin and the far-right pin is the normally open pin. I also know that I want to connect to only these four mentioned in order to get the thing working. What happens now if I test it, is that the computer switches on, runs for a second and switches off and I am not sure as to why this happens. Anybody any advice on this?
My new current system:
MoBo: Gigabyte Aorus x570 Master | CPU: AMD Ryzen 9 5950x | RAM: G-Skill Trident Royal 32gHz @ 3600 mHz | GPU: Zotac RTX 3070 Twin Edge OC | SoundCard: SoundblasterX AE5 white pure| Storage: Toshiba 3TB; Seagate 2TB; WD Blue 4TB; Seagate 8TB Samsung EVO 980 500 GB PCIe 4 NVME; Sabrent 500GB PCIe 4 NVME x 2 | Case: Thermaltake the Tower 900 | Monitor: Toshiba HD 32"; Dell 24"; 7" hardware monitor LCD | PSU: Corsair RM850i | Propellors: Thermaltake Riing plus 12 x 8; Thermaltake Riing plus 14 x 3; Thermaltake Riing sync 12 x 2 and 5 other propellors for a push-pull config on a 360 and 480 rad | Cooling and remaining stuff: dual custom loop with a) one EK D5 Revo pump and b) one EK D5 Quantum Inertia pump.
https://linustechtips.com/topic/1059713-power-button/
Your photo is out of focus
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1059713-power-button/#findComment-12527694
I know. That's why I described it.
https://linustechtips.com/topic/1059713-power-button/#findComment-12527695
So make a new one, so it’s clearer for us to see
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1059713-power-button/#findComment-12527756
Ok, so since everybody apparently has trouble reading, I post another picture here.
https://linustechtips.com/topic/1059713-power-button/#findComment-12527797
So I did. Any answers?
https://linustechtips.com/topic/1059713-power-button/#findComment-12528199
