So when I started this a couple weeks ago I didn’t have in mind to build a wooden test bench, but since I didn’t have the tools to weld pieces apart from the case, I decided to build a wooden bench with some inspiration from YouTube. I’m quite happy about how it turned out in the end and it’s functionality, though it’s not finished yet as I’m gonna drill holes for the cables to go through and the power button will be drilled to the wood. Just need the tools first
https://linustechtips.com/topic/1059620-finished-my-test-bench/
1 hour ago, LukeSavenije said:
maybe something to mount the ssd on?
Looks like there are already two SSD sleds/mounts on the side, OP just didn't use them :P
Hopefully the base is heavy enough that whenever you are mounting something on the motherboard, like a GPU, it doesn't start tipping back.
https://linustechtips.com/topic/1059620-finished-my-test-bench/#findComment-12526994
