So everytime im playing call of duty black ops 2 zombies im fine but as soon as the game ends my monitors black screen and pc fans go all the way up. When i play fortnite mid game my monitors go black screen and my fans go all the way up.
I really need help with this because i have not played fornite in a long time.
https://linustechtips.com/topic/1059499-pc-overheating-problem/
Can I have your build information? (the case, cooling, etc)
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12525578
fortnite
The PC is trying to protect itself from that amount of toxicity lmao
now on topic: specs?
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12525586
15 minutes ago, Duckster said:
nice one xd but for real, SPECS
yeah specs
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12525609
Graphics Chipset - Radeon RX 580 Series
Memory Size - 4096 MB
Memory Type - GDDR5
Core Clock - 1366 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 8 GB
CPU Type - AMD Ryzen 5 1400 Quad-Core Processor
SSD and HDD
Memory Type - GDDR5
SSD and HDD
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12525610
That's a Phanteks Enthoo Eclipse case, the air flows not too bad, but if the fan configuration is janky then it get's pretty hot. Considering it's a budget prebuilt computer I'm guessing either stock cooler or like a 212 Evo for the CPU cooler.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12527050
Black screen and fans shooting to full speed is not exactly a symptom of overheating.  For the most part, overheating means automatic downclocking of hardware and slow performance.
Could be hardware or software fault.  Bad GPU, bad moboard, bad ram, etc...  Do you have a warranty?
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12527127
Then why did the fans shoot to full speed?
https://linustechtips.com/topic/1059499-pc-overheating-problem/#findComment-12527798
