Wraith Prism Cooler
Solved by Wolly9102,
2 minutes ago, TheWiseGuy said:Hello, quick question! Everything with my Wraith Prism Cooler that I got with my 2700x is working well. I use Asus Aura to control the colors, do any of you know how to change the color of the outer ring that lights up?
You can't control the cooler with aura
http://www.coolermaster.com/amd-ryzen-wraith-prism-rgb-software/
Use this instead
