it has the same TDP so yes (btw I run an 2700x and 2070 off 500 watts so you have some headroom ;) )
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1059139-power-usage/#findComment-12521926
3 minutes ago, newbold_57 said:
My bad I meant i5 7600k I fixed the post.
it really depends on how much the 7700K costs, if you can find one for 150$ or less? great, go for it i guess?, but if you want to spend 200-300$ then it's cheaper and much better to upgrade your Motherboard and CPU, for example a Ryzen 5 2600 and a B450 Motherboard would cost around 250-300$, and if you wanna go that route, I should mention that Zen 2 (Ryzen 3000) is coming out pretty soon.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1059139-power-usage/#findComment-12522016
On 4/28/2019 at 11:09 PM, newbold_57 said:
Hello, I currently have an i5 7600k and I am considering upgrading to an i7 7700k
Not really worth the money.
YOu pay 200€ or something like that for the slight improvement.
Yes, you need a new Motherboard but that's a rather small price to pay for the performance you can really get.
Since you already have a decent system, why not wait another month or so and come back and ask what makes sense at that time???
I was wondering if it would be safe to use my 500 watt power supply if I get the 7700k or if I should upgrade. Thanks for the help.
Here are my specs:
https://pcpartpicker.com/list/Nmvyhy
You should upgrade the PSU to a higher end/better one anyway.
The wattage isn't a Problem at all, its the Quality of the PSU that is.
The old CX500 isn't a great PSU.
Look at the Tier List (the new one), TierB or better.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1059139-power-usage/#findComment-12525738
42 minutes ago, newbold_57 said:
well it is used and the guy is asking 225 for it so I figured I'd offer him $150
That's still a really high price for a 4 Core CPU, even with SMT.
A similar modern 4 Core PRocessor is less than 150€.
For 150€ you can get a decent entry level 6 Core CPU, if you'd change the Board.
And that will last you longer than the 4 Core you are wasting your money on...
https://linustechtips.com/topic/1059139-power-usage/#findComment-12525741
