Alienware M17X Repair Help
Solved by Skiiwee29,
1 minute ago, brianp1999 said:Maybe I should've clarified better, is there a way to reset bios without removing cmos battery. It's not that I'm incapable of following the guides, im just being lazy :)
Older laptops use to have a pin hole you could go through with like a paper clip to reset the laptop, not sure thats around anymore honestly. But if your googling didnt reveal anything, then likely not.
