My friend is building his first pc and he's picked a 1660 and ive recommended an i5 9400f. were trying to find a good mobo now but found this.
https://www.amazon.co.uk/ASUS-EX-B250-V7-Expedition-LGA1151-Motherboard/dp/B074WHNWZT/ref=sr_1_fkmrnull_1?keywords=ASUS+EX-B250-V7&qid=1556130679&s=gateway&sr=8-1-fkmrnull#customerReviews
on the asus support page for this board the cpu doesnt show to be compatible. they're both 1151 so im a bit confused atm.
Ryzen 5 5600x, GTX 1070 Duel Asus OC Edition, 16gb ram, Asus Tuf Gaming x570-plus
https://linustechtips.com/topic/1057885-cpu-and-mobo-compatibility/
There are 2 versions of 1151, B250 uses the old version for 6th and 7th gen CPUs. You need the new version for 8th and 9th gen.
This can be found on 300 series chipsets like B360, B365, Z370, Z390, etc.
Primary PC:
PSU tier list
How many watts do I need?
do you have any recommendations please? trying to keep the buidld as cheap as possible. so far. £200 for the 1660 and £140 for the i5 9400f.
found a £40 WD 500gb SSD.
12 minutes ago, cheiften98 said:
ah ok, thank you.
Where are you from?
Personal Desktop":
Luna, the temporary Desktop:
Just now, LukeSavenije said:
that's a ripoff
I'd recommend to go 2600+b450 tho
is that a joke about the ssd?
i picked the i5 9400f  as its better for cpu heavy games over the 2600. arma 3 and stuff like that.
Uk, why?
https://www.morecomputers.com/a?pid=B365M PRO4>>ASRock&referer=PCPart
This would fit an i5 9400F like a glove
Personal Desktop":
oh, i thought it was a hdd... my bad
9400f will show it's age faster tho... only 6 threads
the 2600 is 6 threads too. im still running a xeon 1231v3. gonna upgrade maybe black friday tho.
5 minutes ago, LukeSavenije said:
and you can sometimes find a good motherboard like the b450 pro4 for around 60 bucks...
so have a good look
my friend just said his budget is £750 so i think ima look into a higher end i5 or maybe even a i7 now. its easier to go cheap on the ram and case. i thought his budget was lower xD.
oh... fun! have a free of charge list
1 hour ago, LukeSavenije said:
thanks dude :P appreciate you doing that. i think were gonna go with the 2600.
which amd motherboard to i go with? most on pc part picker say they need bios updates. this is my friends first pc so dont want to drop him in that straight away. as i dont live near him.
then I'd get a b365 or z390 for intel
b450 or x470 for amd
those have native support for current chips
