I run a 4690k and a GTX 1080 SC in my pc and get quite a hefty bottleneck, playing rust I see that my CPU is at 90-100% and my GPU at 50 or 60%. I have installed a 280mm h110i water cooler for my CPU since I need an overclock. I run all my temps off of NZXT software called CAM that works for the fans in my case.
I need help overclocking since I've never been in contact with it before, am using an ASUS board (z97 gryphon armour). Could someone help walk me through what I need to do to overclock so I can use the whole of my GPU.
https://linustechtips.com/topic/1057494-4690k-overclocking-help/
The thing is that overclocking via YouTube tutorials will help a ton more than a typed up instruction. Also, that's quite a lot of work.
Search for it yourself, and apply this advice: get the highest CPU frequency you can and keep lowering the voltage to get the lowest stable possible.
Not sure that'll happen, depending on the game a quad core isn't enough, even a fast one.
Primary PC:
PSU tier list
How many watts do I need?
but how do I know when its stable though
stable is when your CPU cooler can handle the heat and when the computer doesn't crash when you do the things it needs to do. My go to test for stability is an Aida64 stress test for 10 minutes.
Primary PC:
PSU tier list
yeah have heard of stress tests, just not sure on how to read the results, does it just say stable or unstable
Id start with rasing VCCIN to 2.0V, also stay bellow 1.4V core voltage. My I5 4690K did 4.7GHz at 1.335V for reference, and thats seen as quite good.
Builds:
not sure what the difference between normal voltage and core voltage is and all that stuff
VCCIN is the voltage fed from the VRM to the CPU and core voltage is the voltage that the Fully Intergrated Voltage Regulator(FIVR) spits out to the cores from those 2V
Builds:
simpler:
STABLE is when the system runs
UNSTABLE is when the system crashes.
If your games, programs, or operating system can't run with the OC you set, it's unstable. There's no text readout that says "unstable" or "stable"
Primary PC:
PSU tier list
7 minutes ago, fasauceome said:
simpler:
oh and another weird thing is that I have 8gb of Ram installed, and it used to read 8 in settings. But when upgraded GPU then there was a red light on a RAM led or something and then my pc didn't turn on, I switched the sticks around and the pc turned on but my settings now say I have 4gb of ram. Do you know what this could be
It's possible that there's just a small error, have you tried once again to get back to 8GB? Also resetting the BIOS to optimized defaults might help
Primary PC:
PSU tier list
what do you mean get back to 8gb
I mean that you used to have your PC show that you have 8GB, what have you tried to get that back?
Primary PC:
PSU tier list
nothing, don't really want to touch the sticks again since, tbh I'm scared the pc might not turn on again
There's not really a huge risk of that, plus 4GB is gonna be your main issue of that's all you're stuck with. Clearing up the CPU bottleneck won't yield much performance uplift if you lack the ram needed for your games.
Primary PC:
PSU tier list
what config should I put my sticks into then? 1st and 3rd slot or 2nd and 4th
The green slots
And if you want to be sure of eliminating risk, don't forget to unplug the PC when you swap around hardware
Primary PC:
PSU tier list
Primary PC:
PSU tier list
4 minutes ago, oskarnedreaas said:
I just switched and got my 8gb back, I went to 4.6 ghz and 1.2 volts but my pc crashed. Do I down the voltage or the frequency
4.6GHz at 1.25 might work
With a 280mm water cooler, you can handle more.
Edited by fasauceome
Primary PC:
PSU tier list
wow yeah it booted, am gonna install aida64 and see what it reads. if my temps go over 80 degrees should I tune down the voltage?
Over 80 degrees in Aida is fine, I would say 95 and up is something that needs adjusting.
Primary PC:
PSU tier list
