This may be a dumb question but I just got a 1080 ti for my friend extremely cheap ($200) but it has a blower-style cooler. I have a broken Gigabyte Windforce OC 1070 ti that has a functioning three fan cooler but the actually card is dead. Could I move that cooler over to the 1080 ti? Sorry if this is a stupid question for one reason or another I just cant find a straight answer online. Thanks in advance!
https://linustechtips.com/topic/1056579-dumb-cooler-question/
A 1080ti would likely be too high powered for me to be comfortable not having direct cooling to VRMs and GGDR. Also components may block the heatsink from fitting properly.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/1056579-dumb-cooler-question/#findComment-12498913
Depending on the card, could still find a hybrid cooler. Or a open air cooler for the same board.
https://linustechtips.com/topic/1056579-dumb-cooler-question/#findComment-12501140
