Fan speeds rev up and down
Kvahuest
Since its getting hotting my pc will be getting hotter but for some reason my fans rev up then go back down, is there a way i can control them and stop them ramping up, my cpu is at 40c and my gpu is at 70c as it always is
Could just be a sensor error or smthn like that. Try for a BIOS update and/or custom fan speeds in BIOS. Most computers, even laptops, have the option for the latter
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
this may be a dumb question but where do i check for a bios update?
Your motherboard's support page.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Which fans are revving up and down and which header are they being plugged into?
This is usually from a fan curve that's too aggressive. Find out what fan speed they're running at and at what temps. You can make the curve less steep to reduce the fan speed changes.
i believe it was the weather since it was really hot in my room at that time, i closed my blinds and cooled my room down hasnt occurred since, but ill update my bios if it needs to tomorrow
it doesnt need a bios update, the last update was 4 years ago, guess its just the weather
