I an having an issues in Apex where sometimes I am getting 144fps constant, and then alter I will be getting really low FPS all the time.
I checked in MSI Afterburner and it seems that my GPu usage is fairly low quite a lot.
The clocks don't dip on either the GPU or CPU so it doesn't seem to be hardware related. Tried taking of OC and it's the same.
Is this serve related?
https://imgur.com/a/7UQzcQi
https://linustechtips.com/topic/1056001-low-gpu-usage/
It could be server side it could be your network. It could be your OS install. It could be something running in the background.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493745
Your OS install, what do you mean by that?
Nothing is running it's completely clean, installed again the other day.
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493788
I had some major issues with windows 1809 build myself almost crippling my systems for gaming.
|King Of The Lost|
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493794
Just now, benjiven said:
How did you solve it. 1903 was worse for me, much more stuttering.
I rolled back to 1803 where everything was much better for me on all my systems running Windows 10 Pro x64
|King Of The Lost|
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493807
What sort of issues did you face on 1809?
Very very low FPS, stuttering, input latency was through the roof. Daily usage was worse with the system overall being slower.
|King Of The Lost|
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493819
That seems very strange, I don't think there is that much difference between 1809 and 1803 is there?
Did you try clean re-installs on 1809 first?
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493844
Many clean installs, 5 of them to be exact. All the same issue, 1809 is currently Microsoft's nightmare of a spawn with updates.
|King Of The Lost|
https://linustechtips.com/topic/1056001-low-gpu-usage/#findComment-12493849
