You could try cloning it, though that can be finicky.
Otherwise install the OS on the SSD like normal, then follow this guide to "import" your stuff over:
Once you're satisfied, reformat the HDD.
https://linustechtips.com/topic/1055667-ssd-upgrade-help/#findComment-12490582
I want to keep the files that are on the HDD on the HDD. All I want is to uninstall the copy of windows from that HDD. Is that Possible?
https://linustechtips.com/topic/1055667-ssd-upgrade-help/#findComment-12490594
You could just manually remove the boot partitions and delete system files you dont need on the HDD, sadly I'm unaware of any automated way for that
Desktop benching:
https://linustechtips.com/topic/1055667-ssd-upgrade-help/#findComment-12490625
9 minutes ago, Charmander said:
Ok, I thought about that but don't have a lot of time for it. Thanks
Temporarily put everything you want to keep in the SSD, and then format the HDD —> put stuff back on clean HDD.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1055667-ssd-upgrade-help/#findComment-12490650
