My Samsung micro 32gb EVO SD card is not showing up on my phone anymore (Galaxy s8 plus). At first it would say connect the SD card and I would go into my storage and it would be there but I couldn't use it. So I restarted my phone a couple of times then it worked. But a couple days after that it just stopped showing up. So I got a new samaung 128gb EVO to see if I could transfer the files from my computer but the old card doesn't show up on my computer either. The card is 6 years old so wasn't sure if I could try something or is it just dead. Thanks.
https://linustechtips.com/topic/1055301-micro-sd-card-not-showing-up/
On 4/17/2019 at 3:23 AM, Pro Hustler said:
You must've ever locked your SD card from your phone.
Try to use it from another mobile and if possible format. Recovering the data involved could be a tough task in such cases.
Thank you
