Hello, For some time I have a message cpu fan fail warning control check that sometimes appears on before booting my OS, I looked at all my cables are plugged the fan turns I wondered where it can come from and if I had to disable the option in the bios for disable this message. I have normal temperatures even while stressing the CPU (below 80 ° under occt for 1 hour). I also noticed that once on the bios there were spades for the rpm of my fan cpu he went from 128 to 0 while that base speed is 16X -170x so maybe he put it on 0 because it's too low for the motherbord.
In passing I moved recently but the message and appeared maybe 1 week later and it would surprise me that the pc and move with all the protections that I put in any case I do not notice anything abnormal when i open the computeur.
motherbord  :MSI MAG Z390 TOMAHAWK
CPU Cooler :Be Quiet! Dark Rock Pro 4
A screen when i don't have any error :
Thanks for the anwser :D
https://linustechtips.com/topic/1055195-msi-cpu-fan-warning/
Shouldn’t a fan spin somewhere in the region of 600-1400rpm depending on model etc..
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1055195-msi-cpu-fan-warning/#findComment-12486293
This
Get yourself a fan just in case your current one actually fails
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/1055195-msi-cpu-fan-warning/#findComment-12486320
