12 minutes ago, Xarius2319 said:
looking on advice about the fans
Throw in some intake fans at the front, and exhaust fans at the back and top.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1055059-advice-on-fan-set-up/#findComment-12485198
17 minutes ago, Xarius2319 said:
thank you, also have a spare fan is it worth putting second fan on cpu heatsink or not really?
Yes I had a evo 212 I did that with.  Two fans on it and it worked the same as if I had liquid cooling.  You just might to open your side case panel when doing extreme stuff.  So like the guru said,  front intake blowing cool air into the case and a exhaust to push the hot air out and the top to push hot air out the case.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1055059-advice-on-fan-set-up/#findComment-12485238
  • 2 weeks later...
On 4/16/2019 at 12:22 AM, Xarius2319 said:
Okay so i have the NZXT s340 Elite case, was looking on advice about the fans, i have room for 2 120 at the front, one 120 (exhaust) at the back and one 120 on top but no filter so should i have 2 exhausts or 1 on top and the back one as intake?
Use 140s, not 120s, as they are much quieter. All fan positions in that case supports 140s, apart from the rear exhaust. So, ideally, you want two 140s at the front, one 140 at the top, and one 120 at the rear.
https://linustechtips.com/topic/1055059-advice-on-fan-set-up/#findComment-12528105
