Hey guys,
So if you're delliding a CPU and you use liquid metal you have to make sure that no liquid metal spills off of the die and touch capacitors around it so I wanted to know if theres some sort of thin and cheap isolation compound available that you can just put around the cpu die to make sure that there will be no shortages?
thanks in advance,
Vintovka
https://linustechtips.com/topic/1054966-cpu-delid-isolation-compound/
Leave it uncovered and also dont seal the IHS also. Delidding a CPU is not as scarry as liquid cooling.
I dare to delid CPU without covering any pins and without re-seal the IHS, but I never dare to use liquid cooling yet..
Delid only risks a CPU, while liquid cooling risks almost the whole system, the whole money..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Nail hardener or polish with nitrocellulose.
18 hours ago, Zat0ichi said:
I couldn't find classic nail polish. I found nail "gel".
Stank of solvent and made a barrier when I did a test splodge. So I guess its the same thing although the i5 3570 doesn't have any exposed caps so i didn't need it.
i think only the Haswell and DEvils Canyon i5s have exposed caps
