I have a b250 prime pro, i recently bought new ram, i already had corsair DDR4 2133hz 2x4GB
i bought the same ram with the same chip also 2x4 GB
i installed all 4 sticks of ram into my B250 prime pro mother board and i get a black screen, fans on but no display
i wondered if it was my power supply but i have a 650w so i was a little confused
i switched all sticks around in each slots and still a black screen so i took one stick out and my pc booted so i thought the stick i took out was dead, i switched one of the sticks already in with the so called "dead" stick and it worked again
i cant seem to use all 4 sticks of ram in my pc other wise i get a black screen
i cant fix :(
https://linustechtips.com/topic/1054892-ram-problem/
i cant fix :(
did you tried to remove your old stick use use the new 2x4?
Ryzen 5 1600 | Gigabyte GA-AB350M-Gaming 3 | Team Elite TForce Delta RGB 2x8 16GB 3200mhz | Gigabyte GTX 1060 6GB AORUS | Fractal Design Arc Mini R2 | 2 1TB WD Blue | Wester Digital Blue 3D NAND 500GB | SeaSonic M12II 520W 80+ Bronze | CoolerMaster Hyper 212 Led Turbo | ASUS VG248QE | Rakk Kimat XT | Logitech G502 HERO | Massdrop x AKG M220 Pro | V8 Soundcard | BM800 Condenser Mic | Logitech C310
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12484035
16 hours ago, braddzzzz said:
yes all the sticks and ram slots are working
sorry, what i mean is, did you try running your new sticks and remove the old one? when you bought those new sticks, does it come from a single package?
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12486166
Yes, they all came in the same package but the problem is i want to use my old ones too so i get 16gb ram 4x4
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12486922
are you sure all of those sticks are match? even the brand, speed, timings and capacity?
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12487238
59 minutes ago, braddzzzz said:
Yes im 100% sure
seems like compatibility issue to me. if you can test it on to other mobo to see if there is any problem with your DIMM slots.
BTW, when i bought a used 2x4 ram, i was sure that the timings, speed and capacity are the same (check my signature). The only difference between the two is the unit. the first one is Ripjaws and the 2nd hand used RAM is Aegis. before i installed the ram, i turned off the XMP profile on my mobo. right after the installation, my PC didnt boot and stayed at black screen for about 1 minute. I rebooted my PC again and go to BIOS and re-enabled the xmp profile. that works and my RAMs are 100% functioning. why dont you try it? you never mentioned here that you enabled the XMP profile on your rams after you installed them.
Hope this helps.
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12489933
Hope this helps.
ill give it a go now, thanks for the help
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12489957
Hope this helps.
XMP hasn’t worked
https://linustechtips.com/topic/1054892-ram-problem/#findComment-12490310
