What games and at what settings would help. Is it all games or is it specific ones? Are you running any overclocks?
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
Win 10 I get these micro stutters games are not smooth , I recently got a g-snyc monitor. updated all drivers, windows, and as temp s my cpu is typical around 40 c and gpu around 50. Have n’t done any OCS yet …The system is relatively new. The only thing I think of is my ryzen cpu because my friends, and my sister have the latest intel cpus and here I am the only one with the stuttering issues i as in games i play rn are rainbow six and  fortnite everything is low/off besides textures and view distance are on max
Maybe try lowering the view distance a notch and see if that helps or try overclocking your cpu a little if you can.
Cosmos Sv2:
  • OS: Win 10 Pro
Old School AMD:
  • GPU: XFX HD 7950
  • PSU: Corsair 650W
