So, I'm saving up to build a beast gaming PC, and this is going to be my first build. I am doing it with a friend who has built computers and workstations before. I will be playing and doing some streaming with this PC. I was going to go with an i7 8700k, but he recommended a Ryzen 7 1700x, but I saw Linus substituting a 2700x Ryzen 7 for an 8700k i7, so should I go with the 2700x instead? I also need help with figuring out if my case will be good for the motherboard I'm purchasing. Along with this I was wondering if people had any good tips and would recommend any cooling for my PC, if I should buy more fans, and also any controllers that would help with RGB and other quality of life improvements for making this process smooth. Thanks in advance! Below I'll show what specs I'm currently looking at with their prices.
2070 - 499.99
AMD Ryzen 7 1700x - 169.99
MSI B450 Gaming Pro Carbon AC AM4 ATX Motherboard- 129.99
NZXT H700i - 197 https://www.newegg.com/Product/Product.aspx?item=N82E16811146273
Corsair Vengeance 16gb - 103.99
WD Blue 3D NAND 2TB Internal SSD - 239.99
EVGA 750W 80+ Gold - 99.53
Corsair H100i Hydro Series Platinum Processor Liquid Cooling 120mm - 159.99
Windows 10 Home - 139.99
https://linustechtips.com/topic/1054442-my-first-pc-build/
Do you know what display you intend to use? What resolution/refresh rate?
and what's your budget?
https://linustechtips.com/topic/1054442-my-first-pc-build/#findComment-12479755
The 2700x is better in gaming, so if gaming is a focus with the PC, I'd say money well spent. Alternatively, the Ryzen 5 2600 is also better for gaming than the 1700x, so you can consider a balance between cores and game performance with that.
Also, attach a pcpartpicker.com list, it's a far better format.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1054442-my-first-pc-build/#findComment-12479756
Just now, Bedrockgaming said:
My Budget is 2,000 max. I want to get a 1080p 144hz monitor.
under 2000 with a 1440p 144hz display
https://linustechtips.com/topic/1054442-my-first-pc-build/#findComment-12480226
1 hour ago, Slottr said:
This looks really good! I think I'll use this, thanks for the advice!
https://linustechtips.com/topic/1054442-my-first-pc-build/#findComment-12480396
